Vaccum Brake Conversion
mr.ricoe
Tryng to convert my 87 GN from a powermaster to vaccum brake system, does anyone have a instruction list of what's require to make this possible.
Follow the directions above - the hardest part is getting the old pedal out from under the dash. I took the driver's seat out for more room but it is a pain to do.
I put clamps on all vacuum hoses as well.
BTW - with the powermaster out of the way it is a good time to upgrade to a jeep steering shaft.
Good luck. It's handy to have some universal joints for your socket wrench to get to some of the bolts when working under the dash. You'll be a little sore from that part of the job. :)
Has anyone used the 2 inch bigger b body booster yet it is pretty common for the na g bodies to upgrade to it there is a write up on another message board.
