This has got to be something simple. THe car ran good when I pulled the motor last week to have new guides put it it had started smoking a little. While I had it out I found one pison had some small cracks in it from teh blown headgasket it had when I got the car. So the entire motor is rebuilt.
At any rate when I disassembled it I market all wires and hoses even though most plugs will only go one place and the lengths pretty much csho where they go. I tie them all out of the way and nothing was snagged on pullout or reinstall. I got all wires plugged back in and the 4 grounds in the back grounded on a stud on the rear intake bolt. I dont have any wires left over that I can find the crank and cam sensor wires are plugged in. I turned the key and cycled the pumpo she had 50 psi on guage everything seems to work good. So I turn it over to see if it will fire and get no hits or anything.
I pull the cam sensor cap and #1 plud turn it to TDC and all lines up and sensor is turnning properly. I put the Trans Am Sensor cap back on and have my wife turn it over and no light on the cap to show it is in phase. I move it around some just checking and nothing.
I am not sure what I might have missed. Everything looks hooked up and it all worked a week ago when I pulled the motor last week. I did have the battery disconnected for the week. the scan master needs the tuning adjustments put back in but shouldn't have anything to do with no fire.
Any ideas would be greatly appreciated.
