Turbo'd LS swap Gbody guys.. GET IN HERE!
Stroker-ace
Boosted-brick
I hvae a few questions :)
1: do you HAVE to remove your A/C box in order to run a turbo? or even the motor for that matter?
2: is there a write up on using ford headers to run a turbo in the stock location? I found threads where people were using them but nothing informative.
3: is anyone running A/C with thier setup?
thanks for any answers.
my ac didnt work but man it would be tough to keep it. i cut the hump out of mine and will seal it flat so i can have heat. back of the valve cover wants to be in the heater box also. i am using the truck manifold on the driver side upside down and after much debate making a log with merge on the pass side. you caught me right in the middle of this so my mistakes may help you. this is one of those you don't know anything until you do it kind of projects. kinda like a big model with no instructions and a welder instead of glue. ls1tech.com is amazing. these guys are way into turbo lsx stuff and VERY LITTLE BS. all the stuff i have bought and the info has been great unlike the mustang sites.what tranny are you gonna use?
