W wb_7354 Active Member Joined May 31, 2008 May 21, 2017 #1 I have a turbo that I have no idea what it is. What I do know is. It has a precision .63 exh. Housing A/R .70 intake housing. I measured the wheels. See pics. Tia for input/feedback Sent from my iPhone using Tapatalk
W wb_7354 Active Member Joined May 31, 2008 May 21, 2017 #2 wb_7354 said: I have a turbo that I have no idea what it is. What I do know is. It has a precision .63 exh. Housing A/R .70 intake housing. I measured the wheels. See pics. Tia for input/feedback Sent from my iPhone using Tapatalk Click to expand... Sent from my iPhone using Tapatalk
W wb_7354 Active Member Joined May 31, 2008 May 22, 2017 #3 Anybody??? Sent from my iPhone using Tapatalk
F forcefed3.8's Buckeye Bullet Joined May 26, 2002 May 22, 2017 #4 70mm compressor and p trim turbine.
W wb_7354 Active Member Joined May 31, 2008 May 22, 2017 #5 forcefed3.8's said: 70mm compressor and p trim turbine. Click to expand... Is this a good turbo? Do you have any idea what it's worth? Sent from my iPhone using Tapatalk
F forcefed3.8's Buckeye Bullet Joined May 26, 2002 May 22, 2017 #6 It is a decent turbo, outdated. The compressor will outflow the turbine. Not really worth much. 600 tops, and that is on the very high side.
W wb_7354 Active Member Joined May 31, 2008 May 23, 2017 #7 forcefed3.8's said: It is a decent turbo, outdated. The compressor will outflow the turbine. Not really worth much. 600 tops, and that is on the very high side. Click to expand... Thank you! Sent from my iPhone using Tapatalk
