For the record, all new build TA-49 turbos that come from PTE today have the .63 A/R Precision turbine housing installed. From the looks of it, that looks like a TA-49 turbo. The only two ways to know for sure would be to:
1. Unbolt the downpipe elbow from the side of the turbine housing, via 4 bolts, and look for the turbine housing part number. If you see a THB3-31, that means it has a T31 turbine wheel, which was/is standard for the TA-49 turbo.
2. I know this next step might be very hard to do, but it's the only real way to ID the turbo. Loosen your hose clamps on the compressor cover discharge of the turbo. Now you will have to slide the intercooler hose back onto the intercooler, enough that you can see/read the engravers makings on the compressor cover discharge. With a stock intercooler in place, it may be necessary to loosen/remove the intercooler bracket bolts in order to rotate the intercooler away from the turbo. You might also have to loosen the clamp on the t-body hose and either pull the inlet pipe hose off or remove it completely. This is only if you are going to rotate the intercooler away from the turbo. Very tough job with a stock intercooler that has the shroud installed. Hopefully you will be able to slide the intercooler hose onto the intercooler and read the engravers marks.
Get those markings numbers and let us know what you find.
My best guess is, that is you have a stock torque converter in the car and it has just a little bit of lag from a punch, it's probably a TA-49. As anything larger than this would have significant turbo lag from a punch with a stock converter.
HTH
Patrick
