Mr. Upholsterer
Smoking the Buick
- Jan 9, 2010
I read something about Rocker Arm Buttons and that they have a new plastic for them....?? What is is Polyurathane...Tried pushing one of the old ones out and the button broke.. Should I use any special rings for the forged pistons and a turbo ??
When I first saw them I said What the F__K??!! talk about a hot spot !! What does that do the Flame Front ?? Crazy Design...Had to be where they poured in the metal into the cast for them and never bothered to to grind it off... Snowing for a while here in PA this morning...They said the sun would be out and in the 50's.....I don't see it...
Well Guys I broke the engine down today...Found out that I have double dimple rods in it.... That's Strange...Isn't this just like GN stuff ?? Also My cam was a Bitch to get out...I actually had to hit the flange on the back side it get it out...I couldn't even turn it with my hands...Sprayed a ton of WD-40 and was able to at least get it out...Seems like maybe the thing was not cut right or something..Will have to let the machine shop check it out. The lifters were tough to get out to...they were kind of mushroomed over ....My lifter remover only helped a little...ended up using a Vise grip on them with a large screw driver behind it for some leverage and hit the Vise Grip with a hammer and walked them out that way... Now to just do a little bit of degrease so I don't curd up my truck when I take this stuff to the machine shop next week..
82 and up all engines had the 2 dot rods. Your exprerience taking this motor apart sounds just like mine. I myself don't buy into the "zddp+ is needed to keep your engine alive" My race car buddies have proved to me it's not needed. By the looks of your motor it has leaked quite a bit so I'm sure it's had plenty of low oil runs and lack of oil changes. Believe it or not, not everybody changes their oil every 3k and even if it's a performance car it still doesn't mean it was taken care of. Just my two cents
Just took the heads apart, Lots of caked up crap on those intakes. I see the valves are dished...cool... What kind of valve guide seals should I use ?? Also should I glass bead the head right where the valves seats are ??
