Correct.
Timing control is done by the program in the chip inside the computer. And will vary from chip maker to chip maker.
As is engine idle speed, coolant fan, tq converter lockup, egr, boost control, etc etc etc. Its all done by the chip.
Only adjustment you can do is throttle position, throttle blade opening, and cam sensor sync. Fuel pressure IF you have an adjustable regulator.
