TH400 Cable Lever bracket
KWIKR 1
I'm missing the shiffting lever on my TH400 . and I forgot how I had my old one setup . can I use a 200r4 lever....or ? Using a Turbo-Action CHEETAH SCS SHIFTER . Thanks
you need the selector lever bracket that would have been supplied with the shifter
Nope dont have it . From what i remember it came with a modded stock lever . i guess for the steering column lock . and for the life of me i cant find it .
I saw that .....thanks . but I will lose the streering column lock . I guess thats not a big deal . The one I had on before was a modded stock lever someone had made . It was left on when I sold the trans .
you need to find a stock 2004r bracket and bolt it over the cheetah bracket (then tack weld it) , that way youll be able to keep the lockout of the column and keep the neutral start and reverse lamps without having to wire up switches on the shifter
