I have a te 44 turbo with garret housings that was rebuilt 2 years ago and has less than 7,000 miles on it!i also run a precision prefilter set up that was put on when the turbo was put on.there is a slight bend in one of the fins when i got it back from precision i called and they said it was balanced and was fine.i have ran it flawlessly for 2 years and has made several 11 sec passes even the one in my signature!the compressor housing has been ported,and the wastegate hole opened up but does seal with th down pipe!exhaust housing is a 63,but i do have a 82 housing i will throw in for a little more!would like to get 350.00 thanks!
