Right now the rims I have are 15x10 with a 5.5" backspace and they fit perfect. About 1.5" to the frame and about 2" to the fenders. So given that, how low can I go before the tires rub and/or my 60' starts to suffer? And how much lower did your car get jevans? I kinda want something similar to that stance! Thanks!
Oh I forgot to mention, I have the frame notched and I have the fender lips cut too! So what springs would give you a 2" drop in the front and rear? And any major difference in performance between the Eibach and the Moog springs? thanks
To my knowledge I don't think there's a spring for the Gbody that will achieve 2" drop by itself. I have Belltech 2" Drop Spindles in the front, I cut the Moog's on the rear to get the lower stance. When it comes to a lower stance, probably not much difference between the different brand of springs as far as performance.
Nice that you already have the frame rails notched. A two inch drop on the rear is more than likely going to put the sidewall up inside the wheelwell. As long as you have the clearance, it should work out fine... John
Here's a couple of links you can check out. I like to think between John and myself that we've covered all the bases for lowering a g-body - we just went about it a little differently in the front.
John's build using MOOGs cut down along with dropped spindles: http://www.turbobuick.com/forums/br...pension-upgrade-project.html?highlight=jevans
My build using Eibachs UNCUT in the front along with new front control arms and F-body springs UNCUT in the back: http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/289865-total-suspension-build.html
Here's a pic of my car with only the Eibach springs. In all reality, they only drop the car about 3/4" up front and maybe 1/2" in the back. Actually, after they settled in, the rear ended up lower than the front. You don't want to cut a progressive spring like an Eibach. There's TONS of info on the MOOGs with varying results if you do a search. Either way, they both get the job done.
Here's a current pic of my car with Eibachs and all the other stuff from the build
With street wheels
With race wheels
Coo, good info. So whats the springs that will give me the biggest drop both front and rear? I see there are tons of Moog p/n's but should I just play it safe and get the Eibachs? And if you cut the coil (ie half a coil or one full coil) doesnt the end of the spring like pig tail in? If so how do you cut the spring then do the pig tail curl at the end to make it back to how it was designed?
I think your best route to take would be to do the Fbody springs on the rear like Will did, no cutting or guess work. His ride height is very close to mine, seems to be the best spring only option. Another option would be to cut the springs you have to get the height your looking for. I would trim a 1/4 coil at a time until you get the it where you like it. This is what I did with the Moog 5314's. I fabricated a round tube to use as a locater to keep the spring centered and from falling out when I jack the car up...
Just got the springs from Jegs that Will recommended. Will be installing them this weekend and see if it drops me down to where I want at the rear. Right now I am at 27" from ground to the wheelwell trim. Want to get down to around 26". Have been using cut springs in the rear for years now but don't like the fact that they can become unseated. Will post pics when I finish. Running some thick insolators at the top of the springs now and suppose some work can be done with those if these springs don't lower it enough.
Also found this searching around, not sure if it is all the gospel truth or not.
The Monte Carlo Mailing List: Tech Articles
OK, installed the Hotchis rear springs using the isolators I had and SAME ride height, 27". Took em back out and did the ol make your own isolator deal. Slipped some extra good grade push loc hose around the first coil and now have about 26 5/8". I assume the springs will sag a bit eventually to get down to the height I want which would be around 26" or so. If we get a decent day around here will put some miles on her to help it along otherwise it has all winter to sit before i think about chopping coils. You guys are running M/T's in the back while I am using BFG's so maybe there is a slight height difference between them?
Now I can Dukes of Hazzards jumps without worrying about the springs falling out.:biggrin:
