detaildave
- Feb 5, 2006
Ok heres the story . I rebuilt the entire suspension ,I had other upper lower control arms that i had powder coated , I replaced all the bushings. i put everything back in correctly(Springs seated correctly).My problem is since i did all this the car sits like there is no motor in it ,The only thing i did different was ,i put 5/8 heater hose around the top of the spring ,because the absorber was flattened out. so whats the issue i used the same springs (and they were out for about 8 hrs) I've only driven it about 25 miles since that. I did put KYB shocks on it .So will it slowly go back to the height that it used to sit ? should I loosen up the bolts on the control arms to possibly help it settle ?.Do I need to drive it more. Or get 2inch drop springs ...HELP
