I have changed my converter to a much much tighter unit due to driving throught the other one. I had no problems two stepping and bringing the car up on boost with the looser converter. Now with the tighter converter Ive ran into a new situation. I cannot brake torque the car with out it starting to stumble and sputter around 3000 rpm with this converter the only way I can get the car to come up on two step\boost is to flat foot the excelerator. But comes up extremely slow and has a very noticeable hesitation around that 3000 mark. It seems to happen right at the transition from vacuum to boost about 1.5lbs. Once it gets past that the motor pulls up the the 5200 chip and 12lbs of boost. I will be pro tree racing the car and by no means can do it with the current tune. The motor is a 397 cid Olds with twin 76mm Q trims and Seqential 160lb per hr injectors. Car did a 1.02 60 ft would like to see .980's. Any help is greatly appreciated !!! Thanks
