G GNuisance Hooligan Joined Dec 13, 2013 Jul 25, 2014 #21 scojack_2001 said: PowerLogger and a PLX SM-AFR standalone wideband is my setup Ive had for years. Works great. Click to expand... Do you use a 2-step? See a need or value in it? I'm shoving on the brakes at 0# (stall), so until I do the brakes I'm a little hosed on launches.
S scojack_2001 Livin' Like A Refugee Joined May 24, 2001 Jul 28, 2014 #22 GNuisance said: Do you use a 2-step? See a need or value in it? I'm shoving on the brakes at 0# (stall), so until I do the brakes I'm a little hosed on launches. Click to expand... Nope. No need. I can hold up to 15psi on the (vacuum) brakes. Best 60' so far is a 1.54. Big wheel cylinders in the bad and big shoes too.
W we4Mateo Double you eee what? Joined Apr 7, 2010 Jul 28, 2014 #23 scojack_2001 said: Nope. No need. I can hold up to 15psi on the (vacuum) brakes. Best 60' so far is a 1.54. Big wheel cylinders in the bad and big shoes too. Click to expand... What? You can't do that on vacuum brakes. Posted from the TurboBuick.Com mobile app
