No, no, no. Don't fall for the anti fluoridation propaganda. NOBODY has been hurt by the minute amount of fluoride in in drinking water. Fluoride is needed to strengthen the surface of enamel. Been used for years and really has made a massive difference in the decay rate of teeth in areas where fluoride is added to public drinking water. BTW, some areas of the country have natural occuring fluoride in the water and that isn't hurting anyone either. Fluorine is the 13th most common element in the air and water. Fluoride has been used since WWII and over 144 million people use fluoradiated water safely.Flouride is very BAD for you.
If it was actual Flouride or Flourine in our drinking water that would be a different story. But it's not. Public water is "flouridated" with Sodium Flouride, which is not a naturally ocurring element. It's actually a byproduct from the industrial fertilizer industry. If you think that's safe, then go ahead and keep drinking the water. The myth is that incremental amounts of flouride treated water is good for teeth, yadda, yadda, yadda. Why is it that tap water is not to be used in baby formula? You know why? Because there is no dosage control for infants! If there is no dosage control do you really beleive it is safe?
Small incremental amounts of mercury and arsenic are not lethal either, but you would filter them from your water wouldn't you? So why do you believe flouride is ok? Just because some dentist who is bought and paid for tells you its safe?
Furthermore, sodium flouride has been used since WWII. Hitler used it in experiments in his death camps. It causes a condition called flourosis, which is a weakening of bone density and leads to discoloration of tooth enamel. It also leads to calcification of glands, one of which is the pineal gland.
Look and see what the active ingredient is in Prozac. Please do some research!
Snorting will f up your teeth too with all those crazy faces and grinding of teeth will break down your enamel and the hard ass boogers aint cool D...lol
My wife, my sister and I work in the dental industry and well aware of the bad info out there. Much is misinformation, assumptions and just plain lies. Just like the idiots against immunizations spout. When your done avoiding fluoride go check your tin foil hat for holes, you don't want the radio waves hurting your intelligence.
You must've drunk a ton of it then.The only thing coke is good for is loosening rusted lug nuts...........
Avoid all sodas. Drink Beer.
