Starting issues
Jawbone
Confused
Hi i still cant figure out why my car wont start in the morning or after dark . I did the ecm coil module maf and translator xp fuel pump adjustable regulator and new crank position sensor . Still wont start right !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hi yes im getting fuel pressure holding at 41 pounds . I just replaced regulator and fuel pump and put hotwire kit in yestserday before i did that it wasnt holding but i still have same problem.
Loose grounds on the back of the heads? loose module connector? WHen it doesn;t start go check if you have spark 1st thing. pull a wire off and stick a plug in it and ground it on something.
Ok ill try that tonite after 7 when it doesnt want to start again. My buddy just found a new maf meter gonna try that to. Thanks
Hey everything seems to be tight im getting spark and fuel . When it starts the belt squeals it smokes real bad and engine jumps unless i rev it at 3000 for 3 minutes but that will kill the motor im sure .
