I dug out the specs on the L2471F to see if it serves as a good replacement for the L2481F. I would like to use the L2471F pistons and am trying to determine they will work properly.
I have not found information about top ring placement on either piston. Of course turbo pistons usually have the ring package moved down. Does anyone know if the rings are in the same vertical position on both pistons?
I plan on having the rotating assembly dynamically balanced. So I was not concerned about the 45 gram difference in weight. Make sense or no?
Your thoughts, comments, corrections, and suggestions are welcome.
L2471F and L2481F Specifications
L2471F dish volume: 24.1 cc
L2481F dish volume: 24.5 cc
L2471F ring package: 5/64", 5/64", 3/16"
L2481F ring package: 5/64", 5/64", 3/16"
L2471F ring package vertical placement: ???
L2481F ring package vertical placement: ???
L2471F pin bore diameter: 0.9397"
L2481F pin bore diameter: 0.9398"
L2471F pin bore offset: 0.04"
L2481F pin bore offset: 0.04"
L2471F compression height: 1.825"
L2481F compression height: 1.825"
L2471F weight with pin: 528 grams
L2481F weight with pin: 573 grams
L2471F source: http://www.fme-cat.com/PartDetailWindow.aspx?brand=SD&pt= &PartNumber=L2471F30#.UTm2a9ZaJ8o
L2481F source: http://www.fme-cat.com/PartDetailWi...ged Piston&PartNumber=L-2481F 30#.UTm3I9ZaJ8o
___________________________
Thank you for any help,
Paul Lohr
Paul Lohr
