New in box.
3.830" bore
27 cc dish
.927" pin
1.327" comp height
3.625" stroke
6.350" rod
Depending on head gasket and combustion chamber volume,compression ratio can be anywhere from 8 or 9 to 1 and higher.
If you want to finish the reciprocating assembly,Dave has some pretty good crank and rod deals at Turbo Buick Performance .com
Kit includes 8 pistons,8 pins,16 locks,8 ring support rails,and 6 sets of Hastings pre-gapped standard tension plasma moly rings.
6 of the 8 pistons were sent to Weber,with other parts,for balancing. They have the exact same weight.
The pistons look very much like these except they are dished like the stock pistons.
http://www.ebay.com/itm/Wiseco-Pro-...Parts_Accessories&hash=item417a821c7e&vxp=mtr
$400,00 plus shipping.
3.830" bore
27 cc dish
.927" pin
1.327" comp height
3.625" stroke
6.350" rod
