Sweetblack85
High Powered
- Mar 24, 2014
Scanmaster readings
O2 878-898
Af 07
Lb 48-51
Bat 13.9
Int 128
Bl 118
Mph 00
Clt 173
Ats 71
R 775-800
Tps .44
Iac 64-66
cc 19
nal 00
4 core radiator
Dual fans
160 thermostat
Egr delete
86-87 ecu, ignition coil and maf
Denso platinum plugs msd wires
Turbo tweak chip 42# injectors tuned for hotair conversion
Ported throttle body, intake and heads 3 angle valve job k&n cone air filter upgraded 100# valve springs
Arp head bolts, cometic gaskets
Ported turbo to intake adapter
Upgraded turbo don't know the spec but was told good to 400hp
Just rebuilt engine, headers repaired had cracks, earl timing cover 25# at hot idle
255 racetronix fuel pump sender with hot wire
Caprice 2004r with shift kit billet servo till original gets rebuild
G80 rear moser axles rear disc conversion
O2 878-898
Af 07
Lb 48-51
Bat 13.9
Int 128
Bl 118
Mph 00
Clt 173
Ats 71
R 775-800
Tps .44
Iac 64-66
cc 19
nal 00
4 core radiator
Dual fans
160 thermostat
Egr delete
