bad luck brick
- Aug 28, 2014
I'm getting ready to rebuild my engine.
Car has been sitting for 8 years. A little background. It all started when I decided to upgrade turbo and stock headers and crossover (due to mileage and rewelding headers). During the middle of installation it started drizzling. It did not stop for three months ( El Nino year). Got back to it. Buttoned it up. Cranked on first try. Started looking for exhaust leaks oil leaks etc. It seemed ok until 5 minutes later a started hearing a ticking sound. Still searching when I heard several ticking sounds. I ran to check oil psi and it was zero. Shut it down. Damage was done. Grey smoke, low oil pressure, and fouling plugs. Never ran the same.
Fast forward to today. Been saving money to restore her. In the time she sat her paint faded, interior ripped, etc. No garage. I had bought her a car cover but it did not prevent paint clear from peeling on sun beat side. Other side looks great. I would only cruise making right hand turns. Bahahahaa.
I'm ready to use the defibrillator on her.
Past modification:
1. Xp pump
2. 36 pound blue tops
3. Kenny bell chip for said injectors.
4. Adjustable fuel regulator.
5. Art cart shift kit.
6. B & M trans cooler.
7. Four core radiator 160 thermostat.
8. ATR header and crossover.
9. Turbonetics cheetah stage 1 journal bearings.
10. ATR dual exhaust.
11. Scanmaster.
My goal was to set up a strong foundation for a street car only using 91 octane only. 100 unleaded on occasion.
Scenario 1
I was planning to add the following for the rebiuld.
1. A stock size roller cam.
2. Forged pistons.
3. ARP Head studs.
4. Upgrade to a BB turbo cheetah stg 1
5. Use stock D5 converter.
Any suggestions as to type or brands
Scenario 2
If my stock crank is no good. I was considering a stroker kit. Is this over kill for stock non girdled block? Should I just get a stock stroke forged crank? No clearance issues.
The stroker route would allow me to justify TA SI heads. Or will the stock heads suffice with some bowl work only.
1. Bigger roller cam.
2. Bigger BB turbo.
3. Higher stall lockup converter.
4. Bigger SLIC.
Any suggestions as to type or brands?
If I need to go with a forged crank I would then consider alcohol injection with about 25 to 30 pounds of boost.
With a dual stage turbosmart selector. Low setting 91 octane 17 psi max.
If I use alcohol injection for the first scenario (stock crank stock heads) how much boost is safe (with good tune)?
Is scenario two even worth the extra money ($6000 -$7000) for the performance gain over scenario one?
I'm guessing:
Scenario 1 = mid twelve 91 octane
With alky = mid eleven
Scenario 2 = low twelve 91 octane
With alky mid tens
Any comments, suggestions or stupid remarks?
Thanks in advanced.
Bad luck brick
Sent from my SM-G920V using Tapatalk
Past modification:
1. Xp pump
11. Scanmaster.
Scenario 1
2. Forged pistons.
3. ARP Head studs.
Scenario 2
2. Bigger BB turbo.
4. Bigger SLIC.
I'm guessing:
With alky mid tens
Thanks in advanced.
Bad luck brick
