Santos Moreno
- Jan 20, 2012
I installed a powerlogger after reading several posts and finding the right software and the ways to download it and where to put them. THE car was running pig rich and after I restarted the car it came back but still with a strong odor of unburned fuel. so Here are the readings.
ECM 14.8 COOLANT 165.2
MAF 5.7 INTAKE AIR 78.3
LV8 39 IGN V 13.7
TPS .46 BOOST -29.6
RPM 775 02 .176
WG 0% ADVANCE 21.5
EGR 0% X-COUNTS 224
SPEED 0 KNOCK R 0
IAC 63 KNOCK COUNTS 4
PROG ID 750 INJ PW 3.08
WB AFR 7.36 INJ DUTY 2%
MAP .12
EGT 33
After idling the car for about 1 min the car started hunting and a sevice eng came on and the powerlogger read it as O2 sensor(lean conditions) Im installings a Maftranslator 2 as soon as I get the Plug-n-play harness so any help ahead of time would be helpful.
LV8 39 IGN V 13.7
TPS .46 BOOST -29.6
RPM 775 02 .176
WG 0% ADVANCE 21.5
EGR 0% X-COUNTS 224
SPEED 0 KNOCK R 0
MAP .12
EGT 33
