Flyin Brian
- Jun 18, 2011
I think I know the answer but here goes. Recently freshened motor, cometics, arp bolts. About 20 psi boost no knock but suddenly got the loud farting sound from under hood. Lifted immediately. No water in oil, no oil in water. Car runs fine but when I pull the driver side valve cover breather with the motor running I hear a pffft, pffft, pffft sound that it did not make before. Checked compression and all cylinders are between 170 and 180. Should I borrow a leak down tester or should I just start tearing it down? Did not catch it on a log. Spark plugs look ok. No visible head gasket damage where I can see it. Suspect a minor leak on the intake side of a cylinder but hate to tear it down again. I guess re-torque would be a waste of time at this point.
