im not saying the regualtor will get it right where it needs to be but at least we can tweak it some. things i would do is regualtor, new injectors and a chip. that will be good even for a stock car as parts are getting old and dirty. a new chip and injectors will make the car fell better and get better milage. it all depends on what you want out of the car. the blms like that wont hurt anything if you never plan on doing anything with the car.
Hi again, OK I readjusted the IAC and here are the results:
parked and idle old settings: new setting:
Air Flow -----------05-------------05
L8 engine load -----37-------------35
Volts---------------13.8-----------13.5
INT----------------128------------139
BL-----------------150------------150
MPH---------------00-------------00
CLT----------------185-----------190
ATS---------------103------------75
R------------------725-750-------725-750
TPS----------------42------------42
IAC----------------08------------23
CC-----------------23-255 increment----- counts the same
I had to readjust the TBS since I did readjusted the IAC.
I want your opinion, I think I might have to replace the TBS since after I made the adjustment of .42, and IAC is 23, but WOT reading is only 4.16, and if I remove the TV cable the WOT reading 4.42. Any ideas? Thanks
