I am in the process of getting my '87 GN legal for Northern Virginia emissions, and need to get a PCV setup on the car. I don't know a whole lot about what I need to do to get it legal, not to mention the way things are right now seem a little odd to me.
First, there are currently breathers on the valve covers. From what I have been able to gather, it sounds like I need to get a hold of some stock breathers or the equivalent in order to plumb into the passenger valve cover.
Something I noticed when checking out the vacuum lines; On the rear, passenger side of the vacuum block, there is a line a little larger than the others which goes straight down. It looks like it is connecting to a tube coming up from the block. Is this going to the crank case? Also, if it is, I'm not sure if there was a check valve on there. If there isn't, wouldn't that be pushing boost into the crank case? aka, a bad thing? I blew out the rear main seal not long ago....makes me wonder. Also, if this is plumbing the vacuum block straight to the crank case, wouldn't I then only need to plumb from say, the valve cover to the pre-turbo intake to complete a closed system?
Ultimately, I was thinking it should be set up as such:
(Valve cover) --> (Catch can) --> (Pre-turbo intake)
(Crank case or valve cover) --> (Check valve) --> (Intake manifold) before or after the MAF?
I'm really just basing this on a little internet reading about the purpose of the PCV system and how it is supposed to work. In practice, I have little idea what I should be doing to get this handled. Any help is certainly appreciated.
