wouldn't it be a source for unmetered air??? Air comes in the breathers, up the pcv, and into the throttle body, along with some oil in my case. I know I can put a catch can on the line, but why add more stuff when I can remove it. Dan suggested I put a breather where the pcv is, makes sense I guess. In my case I won't be blocking off the vacuum line as it's also used for my bov.
Yes unless you have speed density and you surely dont need it if your changing your oil frequently. I havent run one in 7 years. No oily mess in the intake and one less hose to blow off or leak.
mine is no longer hooked up, and i have seen no negative issues at this point. The positive is no more oil in the tb.
i have two breathers on the car now and the PCV valve hooked up!!
i guess all i need to do is cap the vac line????
Can some one put a poll on this thread?
