Maybe this is a ridiculous question, but it would seem to be a decent idea....
With an electronic boost controller capable of remotely adjusting the wastegate, and a PAC kit such as Razors that can be turned off (with the gain switch), can a chip be setup to optimally run between a setting of say 'street' 15 to 17psi w/ no alky (controller set low, alky off) and 'race' 23 to 25psi w/ alky (controller set high, alky on).
I have the above setup on my car, but don't necessarily want to run alky all the time. I'd like to have it available in an 'on demand' fashion. I asked Eric this ? on TT board, and he indicated the alky chip would have too much timing for 'street-low boost and no alky' and the street chip would need adjustments (which mean not on the fly) when running alky.
There must be a happy medium that gives both driveability and some performance increase (albeit probably not optimum) when switching between the two modes that doesn't necessitate changing settings on the chip. Would be nice if there was a chip with a 'switch' input for running two sets of parameters.
I currently run an extender chip and also have an older 5.x TT chip. I just installed my Wideband and was wanting to upgrade, perhaps to the 6.0 TT chip, but now I don't know if the above scenario is possible or should I just order an 'alky' chip and run it all the time? What exactly will happen if I run an alky chip with advanced timing, but run low boost and no alky?
