The board here seems to think that 8 psi at idle is enough,as long as you get a 10# per 1000 rpm rise , which I do, but I have a bad oil leak at the front seal. I found a NOS alum. front cover so I'm changing every thing in the front when I finally get time to work on it. If a high volume pump causes any another problems , I would appreciate any input.
