Essentially it was supposed to start last night… but, like all things in this hobby, nothing goes as planned.
We have fuel: verified at the rail.
We now have good fuel: drained tank and added Ultra 94
We have spark: coil packs were swapped and spark @ plug was verified.
All sensor connections are present.
We had an issue with the cam sensor being 180* out… it cranks better now for some reason. How true to the driver’s side of the car does the cam sensor window have to be? Mine is slightly angled toward/favouring the front of the car when installed.
When installing and setting the cam sensor the 1.5” (or 1.45”) marker is the 25* ATDC and the “tape” should extend to the left of the TDC mark when facing the front of the engine, correct? The instructions on GNTTYPE.org do not instruct you to do anything with the crank position when setting the cam sensor. So, we rotated the engine to the edge of the “tape” AFTER installing the sensor housing. The cap is reinstalled and tested for the 7.5v -> 0v setting test. Is this the correct procedure for setting the cam senor, or am I going to have to do it all over again?
Essentially, what the car is doing is the typical Turbo Buick hard start (one or two full rotations of the engine before engagement) and then there is a very heavy electrical load/draw that causes the lights to dim heavily the dash gauges to shoot up and flicker… and then the car just lugs and dies as the “load” becomes too great for the starter.
Any thoughts or directions are very appreciated.
Thanks,
Thanks,
