turbofabricator
- Mar 7, 2004
I have NEVER installed stock heads on a turbo Buick. I will at least spend 4 hours cleaning up the bowls even if the customer refuses to pay for it.( can't remember that even happening though) because it makes such a huge difference. With the heads off did you at least check the valves and seats? Do not install valve seals on the exhaust valves unless you machine the guides AND use stainless or TTA valves. It is so much work to pull turbo, headers, accessories, manifold and heads that why not improve the heads. You KNOW you will want more power soon anyway. With the heads off I also trim the sides of the rocker pedistals, too. Easier to upgrade to roller rockers later.
I would verify the gutted cat converter, too. What exhaust system do you have? Just unbolt the exhaust behind the converter (look inside to verify its gutted) then drop the exhaust down and bolt it to the lower bolt holes and take it for a test drive. It'll still be quieter than most fart can imports.
