I'm trying to remove my gauge cluster because I heard that the Battery indicator light is in series with the electrical system/charging system. My car has low voltage, so thats why I am doing this.
Now I don't know If I can believe that anyone has ever done this before, because its such a nightmare, I'm in such a bad mood I want to murder things! Here is how far I am currently and what was done.
1. Remove dash bezel
2. Remove padded dash surround
3. loosen nuts on steering column (underdash) to drop it down an inch or so.
4. Remove the screws for the gauge cluster. Also remove screws for the black plastic bracket the cluster is mounted to, also vents are mounted to along with some switches.
5. Push speedo cable clip forwards towards front of car, cable should release.
Now get fucked by the harness that is wrapped around themselves with no room to get to, and get scared shitless in thinking you will never get it back together if you go any further....Thats where I'm at. Heres pics!
Last Pic - See the Green black and red wires(left), they go behind the black plastic and then wrapped around the wires to the white connecter(top rightest connecter) That top rightest connecter is the other harness that is in the center of the picture connected to the wires that are taped twice(blk electrical tap) with the Yellow green black white and probably other colors..........
Any input?
Any input?
