well, just got home where i could post after a long days work. anyways my car ran into some problems once i started going faster with more boost. I added a small amount of timing on the topend (21 from 19) and tryed to raise the boost to 24psi. car would pop like it hit the rev limiter and i would back off the throttle. letting off the gas before the 1000 foot and coasted to a 11.24 @110. Anyways i think my problem is the factory 25 year old coil pack or plug wires not sure. car ran fine at 22psi and 19 deg. timing. i also think my fuel pump is going out since the fuel pressure starts to drop off at the top end of the track . anyways the car would have gone 10.90's for sure. car was picking up over .25 ever 2psi of boost. i was going to run it up to around 28psi but the rpm's cutting out up top was weird so i couldn't. Im going to check it out once i get time. from my data logs everything looks good up top and then pop like it hits the limiter which its not. everything is perfect and it does it in the same spot almost everytime. anyways here is what the pass looked like. should be a 11.00 if i was able to stay in it at 24 psi you do the math at 28-30 psi :biggrin: O and my converter is done. locking it up does about nothing. still slips over 20% at the big end
60-1.56 (foot brake)
330-4.5346
1/8-7.0863
1/8mph-96.22
1000-9.2347
1000mph-109.68
1/4-11.2476
1/4mph-110.11
330-4.5346
1/8-7.0863
1/8mph-96.22
1000-9.2347
1000mph-109.68
1/4-11.2476
1/4mph-110.11
