Just trying to dot all Is and cross all Ts before I get into this suspension work. The feel of the car is very much like a 20 year old, 170K mile machine... not the best for daily driving. Here's a list of what I plan to do... fill in the blanks and let me know if all the parts will work together!
Thanks a ton!!
- Eibach pro-kit springs on all 4 corners
- Edelbrock IAS shocks on all 4 corners
- Tubular upper control arms (front and rear)
- Tubular lower control arms (front)
- Boxed, non adjustable lower control arms (rear)
- Frontend kit from these guys: Performance Suspension Components ::: Your Muscle Car Suspension Experts
- Center link and adjuster sleeves from them aswell
- 17s at some point... what are the best offset (I like the deepest lip possible) and backspacing for these? I'll be going 17x8 and 17x9.5
Will an LS1 brake conversion work with those? I hear it changes the whole spindle setting and Gbody parts' (where I'm getting the tubular control arms from) control arms work with stock spindle!
If I go the dual piston caliper route, everything should bolt up fine, no? Was wondering, although the DP caliper says it'll work with stock rotor... does anyone have experience with gbodyparts 10.5" rotor and would it work with the DP caliper?
Altogether the price tag isn't as staggering as I thought it would be!
Oh yea, about springs and ball joints included with tub. control arms... would it make my car lower than it's current stance or at least keep the same level?
Big thanks to RAMAIR1, 84TXGN and xcessiv for helping me through the whole thing.
Appreciate any points and tips!
Copied from the website... the front end kit includes:
The contents of the Front End Rebuild Kit varies by application, most Kits include:
Upper & Lower Ball Joints
Inner & Outer Tie Rod Ends
Idler Arm
Graphite Impregnated Polyurethane Bushings*
Upper & Lower Control Arm Bushings
Sway Bar Bushing Kit with Brackets
End Link Bushings with Hardware
Polyurethane Tie Rod Boots
Polyurethane Ball Joint Boots
Strut Rod Bushings (Where Applicable)
Some Kits Include Control Arm Bumpers
*All Black Bushings Are Graphite Impregnated Polyurethane
Thanks a ton!!
Idler Arm
