jpwalt1987
- Nov 9, 2003
New turbo came in from ReedPatridge@ WORK TURBO!! Borgwarner SXE T4.
69mm compressor/73mm turbine with a .88 A/R.
nice looking turbo,i was wondering how the bw would do on a buick especially the response let me know.New turbo came in from ReedPatridge@ WORK TURBO!! Borgwarner SXE T4.
Will you be logging shaft speed?
Very nice!
What engine and what are the build spec's that you are going to put it on?
I thought that was a really cool feature when I was looking at the bw turbos.Will you be logging shaft speed?
Your going to have some fun!Its going on 109 stock stroke engine. All forged internals and girdled, internally balanced with BHJ balancer and JW flywheel. Ported GN1 aluminum heads ( 249 in/ 200 ex @.550), kennebell 70mm TB and plenum, ported stock intake, Chris Hogeland is picking the cam and building the engine, PAC1203s, T and D rockers, RJC front mount, TH400 with a PTC 17 blade convertor, right now I have 80 lb/hr injectors and twin DW 300 pumps plus alky injection. I will have to build a 3.5 inch downpipe for this turbo.
What did you use to weld the V-band flange to the cast housing? I have a big machine.
