nothingman
- Mar 24, 2012
So I've only had this T-Type about a month and the guy i bought it from said it needed an oil pan gasket... So I did that and while it was up I noticed it leaking trans fluid... thought it was the pan gasket but I'm now pretty sure it's leaking from the speedometer pinion and the shift shaft. So I put some lucas oil trans fix fluid and didn't run or move the car and the next couple days it was leaking a lot of fluid onto the ground. Is this a common issue, if it's the shift shaft seal can i replace that seal without removing the trans? i'd take a better look but unfortunately i just moved to the place i'm living so i only have a small jack n two jack stands n no extra cash to get better stuff.... so it's tough for me to get in there an really see the puddle coming out from under the cardboard is the trans fluid that got dirty from leaking.
thanks in advance
thanks in advance
