Rafs-T-Type
Not so Senior Member
- Mar 8, 2009
When a place says "That's the best we can do without giving you an explanation" It's time to take it somewhere else.... Many places don't like to put your car at Negative camber cause they think all it will do is wear down tires....Not True, cause I have had mine at (- 1.5 deg negative camber) for at least 3 yrs now and I am still running the same front tires with minimal wear...I took my car in for an alignment and I gave them Scot W's specs which are:
Camber: - .75 ( + or - .2 )
Caster: + 7.0 ( + or - .5 )
Toe In: 1/16 ( + or - 1/16 )
The results are...
They do toe in degrees. Does a positive toe degree indicate toe out?
Try to get a place to get as close to those alignment specs as possible because those are actually from DSE and it will make a big difference in how the car handles..
PS: Not every car will be the same or be able to reach that exact spec but the closer the better..
Yes, Here is what they recommend:How about ridetech? Do they have alignment suggestions?
I have a lifetime alignment from firestone, so that's where I went. I noticed my car was nice and warmed up when i picked it up too . I called a different firestone and explained my problem to them and they said they would fix it up for me.
I just got my car back from setting it up close to the above alignment specs. We could only get 3.5 degrees of caster out of it. It def drives like a new car though with the new upper tubular arms and all new body bushings. I put on a new steering shaft too. I have a small amount of play where the new shaft meets the old column that I need to look at, but other than that the car drives better than it ever has since I owned it. I'm still breaking in the tires, but I pushed a few corners today and it steers and corners better than ever! Thanks everyone for the help.
Let me know what gets rid of your steering play. I have replaced everything and still have tons of play .
While Scott's car is set up a little differently, the closer you get to 0 degrees camber the better. I prefer between +.1 and -.1 for settings since it will give the least issues with wear overall. One of the interesting things about increasing caster is, when you make a curve, the tires will be running more on the sides so you can develop wear issues that look like you've got a camber issue. That's why, as a rule, I prefer caster no higher than 3.5 degrees for regular street cars. If it's a track car the higher caster will aid in keeping it straight or coming out of a corner.Hey Charlie, if you're watching what are your feelings on +.3 camber?
