joedirtmcd3
- Dec 23, 2006
Hey guys, I'm posting this here because I don't know who else to turn to and I am tired of endlessly searching the internet. I've prepared a Speed Switch circuit using an LM2917 IC which is basically a frequency to voltage converter. It will be used in my Buick 4.1L v6 powered chevette to control nitrous activation.
The car does not have enough traction to launch from a stop with the nitrous turned on. I designed this circuit to be adjustable so I can fine tune it to a specific MPH speed that I will eventually be reading with an Autometer or equivalent Hall Effect sensor in the tailhousing of my 700R4. It is reported that the sensor outputs 16 pulses per revolution. This doesn't tell me much because I do not know what frequency will correspond to what speed. I will most likely need to put a scope in my car and take it for a drive to figure out what the equivalents frequencies are. The other option is if someone already has done this I can estimate the frequencies I will be dealing with and put in a potentiometer with a range that will get me fairly close.
Any body have any idea what the frequency would be close to at 20 or 30mph? I realize it will be different from trans to trans because of the speedo gear in the tailhousing itself. Thanks guys.
