OK guys, as many of you know I have been experimenting with different spring in my car. I ultimate goal was to accomplish a 2" - 2.5" drop on the front of my GN using AFX spindles, which lower the car 7/8, and drop springs. Well from other peoples testimonies and my research, I decided on purchasing MOOG springs instead of spending the big $$$ on actuall lowering springs. So I decided on the MOOG 5658 springs expecting them to lower the car 1" and hope for more! Well the resluts are in:
Tire size 245/40R18 Height of tire 25.7"
Bottom and fender lip in center of wheel well to ground: 25.5"
AFX Spindle 7/8"
Tire size P215/65R15 Height of tire 26"
Stock height of my Limited from ground to fender 27.5"
So assuming I had a stock tire car and installed MOOG 5658 springs, I figure the drop of the actual springs:
bottom of fender lip would be 25.5 + .15 = 25.65"
Add the height of the spindle 25.65 + .875 = 26.525"
Stock height vs 5658 spring 27.5 - 26.525 = .975"
So as of the first measurements I am calculating basically a 1" drop. Although I have jumped up and down on the front end trying to get the springs seated, I am hoping the springs drop another .25 - .5". I would say that it would be safe to assume a .25 drop. So all in all with my set up the springs should give me a total 1.225" drop! The car sits perfectly, although I wont be able to drive it for a long time and enjoy it!
AFX Spindle 7/8"
