Hey guys,
I've seen a few threads about looking for billet pulleys for the hot airs. As has been stated before, March makes a great set of underdrive pulleys for the hot-airs. They have a much smaller crank pulley, a larger water pump pulley, and I believe a stock sized alternator pulley with a cover.
You may have to dremel out the water pump shaft hole to make them fit. The clear powder coat is too thick. You may have to do the same to the crank pulley. I have not test fit mine. My balancer is powdercoated so that would make a difference as well.
I've got a set of these pulleys sitting in my shed (Florida, no basements) because I can't figure out what belts to use. I contacted March directly and they stated that they don't have belt info for the 84 - 85's. If I had an 86-87 I would be golden!!!
Anyone running these? I need numbers for the belts.
Thanks,
Tim
Thanks,
Tim
