Originally posted by Nashty
This is my opinion only OK?
Girdle - mill material off the back of the cap (at the point of highest stress) and then place a back up against it. If the cap was keyed with the girdle, I'd be more of a believer but I don't think as far as cap strength, it is better.
It will help to keep your mains in the block from moving if that's a problem. I think this could be a problem if your crank is flexing causing some deflection in the force vector trying to push the caps around. Iron has some ductility though so it wouldn't immediately crack and fail. Harry Hruska once told me the saw the crank whipping, the mains didn't fail. The motor had steel caps. Oil leaks suck.
Caps - they're steel and bigger. That's good.
Ideally, a girdle that left the back of the cap alone but merely tied the mains to the pan rail might be good.
EDIT:
I'd like to see any failure mode information on a failed bottom end. I'd bet the caps and webbing were failed at that point if the failure was caused by one or the other. Not oiling but stress.
If the webbing pulls out of the block, a girdle will do little to prevent the crank axis from drooping under the pressure. Any movement over a thou will kill the crank. A half inch of steel isn't much to help but I'm certain it will provide some relief. Steel main caps will also provide relief.
BTW, my car has been running mid to low tens for 2 years now and the only thing happening is a possibly widening thrust bearing clearance.
I have a +.005 timing chain at home that is 7 position indexable. A +.010 is also available. Timing slack with the line bored block was zero with this set. I use a billet roller cam with a double roller timing set AND a tensioner. Pump pickup was clean after a year of running and the tensioner showed normal wear.
My only failure has been a thrust bearing. I put steel caps on after that - so far, so good...
