I've had my GN for 4 years now. I want to start driving it some on a regular basis. I have done nothing to it but change the oil and replace batteries. I've only put 400 miles on it and 210 was the commute home.
Anyways, I bought a cold air kit and while installing it minutes ago, I noticed my MAF was installed backwards. What I mean is, there is a "flow direction" molded onto the sensor and it was flowing backwards. This car has had some mods by some reputable shops in middle and south FL. In fact the motor only had 200 miles on it when I picked the car up in north FL. There has been a bit of a hesitation when first pulling off. Could this be the reason? Any reason why it would be backwards or simply a mistake?
Also, while I have your attention, is it possible to increase the fuel press. with the stock Bosch regulator. I have a fuel pressure gauge on the rail and the Walboro 255lph w/ hot wire kit. THe C/A kit recommended increasing fuel pressure. If not what regulator do you recommend? Also in the market for a MAF translator for a Chevy MAF sensor to use on the GN if any readers have one for sale.
Thanks,
Tony
Thanks,
Tony
