BlackBettie6
boost addict
- Nov 23, 2007
here is some of my "datastream" so to say
Setting -Feb, 22,2008. temp is 30F. Its snowing:smile: and i just drove highway 7,8,9 miles.
Symptoms- too many. the major ones are; car will stall opon medium- sharp acceleration. it feels like (ALL the time) when i drive the car that there is somthin squezing or clamping the front crank pulley,on..off..on....off.on..off , and so on. Front and rear Main Seal leak. the batterey has a Draw. Theres 2 kill switches hanging in a "rats nest" under the dash (current project). Vehical Shifts Extreamly violent.. . BL says that its *Taking away Fuel* at Idle, But as i hit the gas its *correcting for a rich Condition* all into upper Rpm.
ScanMaster Says!
o2-low of 140-high of 703
MAF-5 and 6
L8-36 to 39
bat-13.7 (at batt its 14.2)
INT- low of 123 high of 133
Bl-109, (I hate you)
clt- 190 (max ever was 193)
ATS- 85 (Any Method of Testing this?)
Rpm- 750-900 (about 1100 on a cold start for 20 seconds or so once calm, but still in closed loop and fixed at 128, car runs pretty decent)
TPS-.42 (.40 key off)
IAC-30 (150 key off)
Questions- Why is there a 12 pin connector behid my glovebox with no male connector around? Am i Overdiagnosing for a blown trans? (weatherstriping leaks) is slight moisture in the cockpit screwing with electrical components? Is oil from the front crank seal inturupting Crank position sensor signal? Is there a site where i can get info on testing all the sensors? im using a MAF Translator with a 3 inch lt1 MAF, Can i test or Clean the TRANSLATOR?
any kinda feedback or opinions/suggestions at all will help me out, if you can think straight
ScanMaster Says!
MAF-5 and 6
L8-36 to 39
