TURBOPOWERED68
David
- Jan 31, 2006
Better get more injector.... Last week, I was at 70% DC on 120's running equivalent to 11.teens. Your sig says 10.90's comming soon and you just don't have the injector for it on 60's. With that said. If your just testing the waters, you won't look back.
I don't test my fuel because I spray alky on top of the E85. Still testing with it tho.
I would keep the wideband in the 10.3-10.5 range starting off.
You might want to elaborate what your trying to do then. I can't read your mind.. Just trying to help.
You will go further with e85 than 93 and alky, don't understand why you would not use it at the track. There is no target with duty cycle. The general rule is if you are 85% or greater, you should be thinking about bigger. Remember you car add more fuel pressure and get more out of the injector. You can run the 60's on e85 with a gas chip with the fuel pressure cranked up and go just as fast as with gas.
I don't understand why you would want to spray alky on top of E85 either, E85 is all that is needed.
A friend of mine is running e85 with 80lbs injectors on a TT race fuel chip. All he did was up the fuel pressure. The car went 10.7@128 with a soft 1.7x 60'. This is a stock bottom end 3650lbs car. Minor clean up on the heads and a 210 precision roller cam on 25psi with a 6765 billet turbo. He now has 120's on a TT 6.1chip for e85.
If your only going to 22psi, you won't have to worry about the quality. Keep the initial tune to 10.3-10.5 and you can lean it out when You get it dialed in. I ended up at 11.2ish but every car is different.
Write down all your settings in both chips if they don't have memory.
How can you get any less than 10psi?
14degrees at 10psi doesnt seem like real KR. That was probably on a shift or rich KR.
Your too lean at 23psi. 20psi will be cutting it real close too. Just get some injectors and be done with it.
