I have an intermittent problem with my car shutting off, it starts back up after a few cranks but will give no indication before it happens. Setup is a FAST XFI 2.0 with the latest updates. One odd problem I noticed is during cranking the Cam light will flash but after the car is running the LED is off most of the time and will randomly light up but does not keep flashing.
Where should I start trouble shooting? Does the FAST require a constant signal from the cam sensor to stay running or is it only used on startup to figure out the firing order. Thanks
Datar
