I really need help guys. I cant figure out what happened with my car. I just went through a complete rebuild, the car had no problem hitting 10psi before cause that's all I got into it untill I put some "break-in" miles on it. I changed the o2 sensor and now I can't get above 4-5lbs without serious *retard. its so bad that the car almost dies when it happens....I let off the throttle and and then it will still cruise fine.
BLM showed that I was rich so I turned the FP down to 32lbs and this didn't change a thing.
this is all the info I got.
If you need to know anything else I'll try to answer it.
this is my last effort before I put her away for the winter
I hope I can get this thing going with all of your help.
thanks
-Brad-
thanks
-Brad-
