How can I check why my and check Engine light is on
Most auto parts stores will scan for free in hopes that they sell you a part. The port is just under the dash drivers side.
All of the codes are listed on www.gnttype.org
I used this before the sm came out.
its just a two prong metal key that jumps the A and B pin on the ALDL plug under the radio pod
..a paperclip or piece of wire can do the same thing
Same thing as using paper clipe but gm use to make these .but you put it on the aldl top 2 on the right and turn key on but not running and you will get code 12 3 times telling you that you are on diagnostic mode then if you have any mal code it will stsrt flashing something like 2then 3 for like code 23 .it will do it 3 times then if you have any other mal code it will do it agsin
