TheGovernment
- May 2, 2010
So I had all my mods in my sig put in this fall. I ran the car for a week or so and was having problems keeping the boost down. My car is stored for the winter and I was just there and may be taking it out for a trip down to the states soon. My problem is that, the boost will not go below 20psi, no matter how much I loosen the rod. I have a TT chip set for 18 psi, along with 60lbs injectors and the TE-44 turbo, 3" dp. everything was installed at once (also had the cat cut off). Even with the rod floppy loose, it will still creep up to almost 20psi, it just takes a lot longer to get there.
I'm going home this weekend to fiddle with it and was wondering what i should maybe look for.
I'll be getting alky this spring but want to try to get this figured out before I put anything new on again. Everything else seem to be working great. I couldn't mash it since I was getting slight knock, so I just didn't.
thanks in advance
thanks in advance
