So one of my bezels is giving me fits.....well giving me don't fits. Is it something I'm overlooking? Is there a trick to this? Am I possibly missing some kind of mystery clip?
No trick. You probably have a bezel that is warped. That or your header panel is messed up, but I doubt that. Check the corners on both to see if they are square.
Thanks Mike.
I can get it to fit but it requires a little double sided tape in that corner. I may have to get some hard core double sided tape if that will be the fix.
make sure the screws coming up from the bumper filler aren't too long
also there is supposed to be a clip on the side of the bezel that locks into the header, on the repops that clip is flimsy and often breaks , then try some double sided tape or velcro on the side to the header
