I believe in coincidence but I am not so sure I did not cause this. This problem started after I over filled the master cylinder. I topped it off with out pumping the brake pedal and when I did it blew out around the reservoir lid. Is it possible to have damaged the master cylinder internally, say blew out a seal or something that could have set all this in motion. When I removed the brake pressure switch I found brake fluid inside the plug part (in the connector under the weather seal). I also found brake fluid inside the connector on the booster pump (connector that points toward the front of the car). When I found this I thought to myself, this fluid I am seeing is probably spilt from when it blew out. But how did it get behind the rubber seal on both the connectors.............hum. Anyway thanks for your time.
-Update, I tried a different pressure switch and nothing has changed. Pedal hard a brick and not stopping car.
