GTA wheels to keep or not to keep?
Way2QWK, now that I have the adapters for the rear wheels I can use the fronts on the front without the longer wheel studs and rears on the rear I just won't have the wheels spaced out like yours correct?
Thanks again for all the help.
You want to use the "fronts" (ie: the deep lip ones) on the rear and the "rears" on the front. Problem is that if you use a spacer, you stock studs are not long enough to account for the extra spacing. Thus you will need to use longer studs in the front. OR you can use an adapter in the front as well.
If you use the adapter you do not need longer studs.
Ok, so I am about to have some tires mounted and I want to put the best 2 tires on the front of the car. So I need to install them on the rear Wheels Correct?
so when my adapters get here I will just put them on the front with the rear wheels and put the fronts on the rear of the car with no spacers or adapters correct?
Sorry, I know I am wearing you guys out but I don't want to screw this up.
