R
Raist103
Guest
OK here goes I don't know the names of the pieces well but what I have is a Inlet from the intercooler, a middle section, and a exhaust housing. Now I can not remove the inlet housing, not just the cover but the hole thing from the center. I removed the 4 bolts that hold it on but now it just spins. I did the same for the exhaust housing(couple more bolts maybe 6-8) and after a couple light taps with a hammer the housing comes off, not so with the inlet side. I need to remove this, do I have to take the fan out to do this?
I broke 2 bolts off changing the turbo but still want to use it I am plannig on useing the inlet housing and exhaust housing on the newer turbo both almost the same size. TE-60 & TE61.
Just to make it clear I am tring to remove the inlet from the middle section. Exhaust side is fine and already removed and replaced.
either email me at raistlin103@hotmail.com or reply to this and I should get an email telling me there is a new post.
Thanks for all the help
