turbojitsu85
- Aug 23, 2002
On E85 what fp is everyone running especially if you have 60lb injectors stock fuel lines and a walbro pump?
Just food for thought. i was always told with a 340 pump you have to use a bigger return line than stock because it can not return the fuel fast enough through the stock line under boost.
An XFI wont fix your problem. I see you're local. Let me know if I can help you. You have all the equipment to find the problem already.
